Hello everybody,
I've a mesh, from a bifrost alembic export ( with "whrite colorset" select at exportation),
and I can't find the "colorset" output in connection editor panel.
When right cliking on my mesh / colorset editor, I can see my velocity colorset, so it let me think the alembic export is ok.
Also I can see it in my viewport whith diferents color per velocity.
I need this output to connect with Vray vertex color so i could render my fluid using vray with velocity colors.
Thanks for your help and aswers
Hey did you solve this? Im having the same issue. No color sets... None of my channels are being exported. I have color sets enabled under the alembic options. It appears that bifrost actually isnt exporting the channels themselves when I cache.
ah,
assign a lambert material to the bifrost mesh and under mesh display klick on toggle display color attribute...thats it
