Announcements
Mental Ray plugin for Maya 2016 SP1 not working
Greetings,
I've just installed my student version of Autodesk Maya 2016 SP1 and apparently everything is working fine until I've installed Mental Ray for Maya 2016. The installation itself is fine, however when I'm going to load the plugin inside Maya, a message appears in the code box described as:
// Error: line 1: dlopen(/Applications/Autodesk/mentalrayForMaya2016/plug-ins/Mayatomr.bundle, 1): Library not loaded: @executable_path/libsynColor.2016.0.51.dylib
Referenced from: /Applications/Autodesk/mentalrayForMaya2016/plug-ins/Mayatomr.bundle
Reason: image not found (Mayatomr) //
Any solution yet to this kind of problem?
Thank you very much,
Pietro Bernardi
Replies (40)
problem solved from your post, thank you.
