Hi all,
I'm currently running Maya 2020 and I wanted to make a command for the shelf which allows for me to easily Select all, delete by type History and the save the scene, all in one click. I have no clue what I'm doing with scripts, so far I have 1. SelectAll 2. DeleteHistory 3. SaveScene. When I click my command, the only thing that is happening is the 'select all' part. Am I doing something wrong? Thanks in advance.
Solved by mspeer. Go to Solution.
Hi!
You need to mark the end of every command with a semicolon (";")
SelectAll;
