Mayapy 2025 crash with *NodeEditorSavedTabsInfo nodes
sophie.chauvet
sophie.chauvet
We had issues using maya 2025 on our productions.
The issue is a crash that occurs when opening of a scene (using mayapy and mayabatch only) that contains two references of the same file, where that file contains "*NodeEditorSavedTabsInfo*" nodes.
Opening the scene in GUI works fine, and does not cause a crash.
I have performed tests with a vanilla Maya installation (no plugins) for both Maya 2023 and Maya 2025, and the problem only occurs with Maya 2025.
Steps to reproduce :
- create a cube in a cube.ma file in maya 2025
- create a new file referencing cube.ma twice. Save it in assembly.ma
- use mayapy to open the assembly.ma file in python
- scene will crash at opening
Code used in mayapy to open the file :
import maya.cmds as mc
from maya.standalone import initialize
initialize()
fp = r'D:\assembly.ma'
mc.file(fp, open=True, force=True)
Scene is also crashing on farm with maya batch.
By debugging the Maya ASCII file, I was able to identify that these lines in the referenced cube.ma file are causing the bug:
connectAttr "pCubeShape1.msg" "MayaNodeEditorSavedTabsInfo.tgi[0].ni[0].dn";
connectAttr "pCube1.msg" "MayaNodeEditorSavedTabsInfo.tgi[0].ni[1].dn";
Which lead me think maya can't connect twice these attributes without gui anymore.
With the exact same lines, its working in 2023.
Stack trace :
Warning: Unrecognized node type for node 'hyperShadePrimaryNodeEditorSavedTabsInfo'; preserving node information during this session.
Warning: Unrecognized node type for node 'MayaNodeEditorSavedTabsInfo'; preserving node information during this session.
Stack trace:
ntdll.dll!KiUserExceptionDispatcher
DependEngine.dll!Tplug::addToNet
DependEngine.dll!Tplug::copyFlags
Shared.dll!TduplicateCmd::copyPlugFlags
Shared.dll!TduplicateCmd::duplicateSceneFileNodes
Shared.dll!TglobalTranslator::doReadFile
Shared.dll!TfileUtil::readFile
Shared.dll!TfileReferencer::readReference
Shared.dll!TfileReferencer::reloadReference
Shared.dll!TfileReferencer::loadChildren
Shared.dll!TsceneOperator::openFile
Shared.dll!TfileCmd::handleFileOpenFlag
Shared.dll!TfileCmd::handleFlags
Shared.dll!TfileCmd::doCommand
CommandEngine.dll!TpythonInterpreter::dispatchMayaCommand
CommandEngine.dll!pythonDispatchMayaCommand
Shared.dll!TfileCmd::clearRefHierarchies
python311.dll!_PyObject_MakeTpCall
python311.dll!PyObject_Vectorcall
python311.dll!_PyEval_EvalFrameDefault
python311.dll!PyMapping_Check
python311.dll!PyEval_EvalCode
python311.dll!_Py_SourceAsString
python311.dll!PyThread_tss_is_created
python311.dll!_PyRun_SimpleFileObject
python311.dll!_PyRun_AnyFileObject
python311.dll!PyDict_DelItemString
python311.dll!Py_RunMain
python311.dll!Py_RunMain​
EDIT: just a precision : I've tested various namespaces (foo / bar or foo and foo1) on the two refs, it's not solving the problem.
Versions tested :
Autodesk Maya 2025.3
Autodesk Maya 2023.3
We ended up deleting these nodes to avoid the crash. Is there another solution?
Thanks.
brentmc
This is a known issue that was addressed in Maya 2026.2:
MAYA-137713: Mayabatch crashes when nested referencing a scene with MayaNodeEditorSavedTabsInfo
Brent McPherson
Principle Software Developer
sparrishDHAXD
Observer
Observer
Could we get a fix for this in 2025?
