Hi, i was working on a Maya scene for my college project. When i finished i saved the scene like i did with every other scene before. Now i wanted to continue working on the same scene, but it just won't load. I tried importing it, deleted all pref, uninstalled and reinstalled Maya, downloaded the Maya 2018 update, but nothing is working. Once i load the scene Maya completely freezes. Also, an error while opening the scene occurs: Could not find an appropriate startup camera: front. I'm really desperate now, i don't want to start the project from the beginning and i hope you can somehow help me.
I'm sending you the scene trough the following Dropbox link:
https://www.dropbox.com/s/5mnt6v8wtdmp6wd/Room2.mb?dl=0
Solved by Abdulla-Qaladzay. Go to Solution.
Hi @Anonymous
it works just fine on my Maya
-you have a lot of construction history on the meshes
-try to work and save your work with Maya ASCII that way if a bug happened in the scene that will be easier to solve it.because Maya ASCII file is readable by human.
-always try to have back up and use increment and save. cleaning [deleting the old versions that saved with increment and save ] and picking-up the final version of your work is super easy.
here is the file with .ma file might be it open on your pc now:
if it is still not opining maybe the problem is hardware.
Thank you for the tips. The scene was still not loading, but i solved it by installing the different version of the GPU driver. Tanks again!
