Maya scene empty
Maya scene empty
Message 1 of 47
Maya scene empty
Hey so i had some weird issues with cameras not focusing on objects so I restarted the scene in hopes that it would fix itself but instead the scene opens up empty and with nothing in the outliner, but the scene still has the same file size? I had not saved any backup and i fear that a lot of time animating has just been for nothing... I used a couple of references if that could have anything to do with it?
I'm using maya 2018.
Replies (46)
Message 2 of 47
mspeer
Hi!
This file looks like it can be restored.
The file contains several invalid values ("nan"), correct this manual with a text editor.
Replace all "nan" or "nan(ind)" with "0".
Message 3 of 47
It helped! Thank you very much!
Message 4 of 47
This post by mspeer wins. Absolutely. Thank you for helping bail out a student who lost her scene.
Do we need to ask why this problem happens? No! Accept your fate as a Maya user. 🙂
Message 5 of 47
mspeer
Hi!
Most "nan" values are caused by values becoming too large, for example positioning something outside of the valid range of a scene or feeding an invalid output from one node into an other node.
While the second can easily happen, i don't know what people do to get the first "nan" value.
Message 6 of 47
Thanks a Lot !! Issue Solved and saved my 3 days Work!!
Message 7 of 47
is there a easier way to do this instead of reading through the whole thing looking for nan. Kinda dont have time for that.
Message 8 of 47
In notepad you can go to edit > replace which will let you replace all of them at once.
Message 9 of 47
@mspeer I could kiss you right now. I swear down.
I just spent all day doing corrective blendshapes on this high-poly character, and both my last two versions were having this problem when I opened them on my home machine.
I've never been so excited/happy to open an .ma file in Notepad.
Message 10 of 47
ptorrevillas
The main problem is that the defaultFitFactor in the prefs for some reason sometimes get set to 0.0 and this is what generates the NaN values.  What you can do is reset it so you don't have to blow away your current prefs or edit it manually risking corruption and then you should be able to fit your views in your existing scenes and on....
from maya import cmds
cmds.optionVar( floatValue=( "defaultFitFactor", 0.5 ) ) cmds.savePrefs( general=True )
Cheers!
PJ
Message 11 of 47
mspeer
Hi!
This thread has nothing to do with Fit Factor, also the Fit Factor problem is solved in newer Maya versions.
Message 12 of 47
creationasif
thank you so much
Message 13 of 47
Matan_Shilo
Hello
I have a similar issue, I spend 3 days of work.
How can I actually put my hand on these invalid values ("nan"). I don't see in my scene any NAN values.
link to the scene (Drive)
drive.google.com/file/d/1J7yA4hbyJWXDLzgdbbXI4saJHJ9CInuD/view?usp=sharing
Thank you
Message 14 of 47
mspeer
Hi!
Recovered scene attached.
Message 15 of 47
Matan_Shilo
Thank you 🙂
I managed to fix it, at first, I did not know I can actually get it to fix within the Notpad
Thank you 🙂
Message 16 of 47
Is there another reason this would happen. I went through my file and couldn't find "nan" or "nan(ind)".
I opened up one of the other files in the forum to check if I was doing it correct and I was able to find nan.
Message 17 of 47
mspeer
Hi!
Yes, other reasons are also possible.
Message 18 of 47
Message 19 of 47
mspeer
Hi!
This is simply an empty scene not sure what you expect to be inside.
Message 20 of 47
Hi there I'm a student working on a huge semester long senior project and I'm worried this corruption issue has happened to me. I am FREAKING out as there is not way I can redo my whole project at this point in the semester. The error reading file only seems to be happening with my newest files for now, but I'm scared my whole project is messed up as I worked from an older save file to redo all the stuff that got corrupted and it all just happened again. I attached the file.
Is there any way you could PLEASE take a look for me?
