Hello!
So I've been working in maya 2018 and I've never come across this issue before.
Maya randomly crashed, then when i re-opened my file, everything was completely gone. Nothing in outliner/workspace. I googled how to recover temp files, but it didn't seem to work. I thought the file was just corrupted so i started over. I made multiple saves again. but this time, when i opened my most recent save file, instead of everything being gone, just most of my work was gone, and the rest of the items untextured.
https://gyazo.com/ed9fefb76806f95eff990bd8c9cef5aa
(This was the same with all my other saves too)
My files were not super big as i was working in low poly. My one file still says it's 3kb, despite when i open it, there's nothing.
I decided to google more, and i found out i had an issue with -nan(ind) in my script editor.
I found this: https://polycount.com/discussion/194695/help-maya-ate-my-project
Where they told me to replace the -nan(ind) with 0,0.
I tried to do it, and i thought i had but then i opened up my file, and things were still gone, and in the script editor it says: syntax error, etc. https://gyazo.com/9a665605e7ff27df338e0f40ceba3774
I was working on another project today, and the same thing happened to my project, despite being in a completely different project. I replaced the -nan(ind) with 0,0 and that time it worked (only for 1 scene save, i tried to recover other saves and nothing happened), so when i had tried it with my other files, I was confused when it didn't work.
I googled that, and found: https://forums.autodesk.com/t5/maya-forum/maya-crashed-objects-missing/td-p/8255166
which basically says to correct the nan values, which I thought I did but i'm not so sure if that's the problem anymore.
I was wondering if there's something i am doing wrong, missing, If i can/can't recover my files? I'm wondering why this is happening to my files and if there's something i can do to prevent it?
I'm very nervous for starting over again, so if there's any light you can shed on my issue, i would appreciate it!
