Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya Freezes when opening software
5 REPLIES 5
471 Views, 5 Replies
Maya is freezing when opening. I have an i5 16' Mobile Studio Pro by Wacom. I upgraded my nvidia Quadro m600mdriver to the 411.95. And I checked the requirements for Maya2019. I also allowed the app in the firewall. I also have the Windows 10, version 1809. I've also uninstalled and reinstalled Maya.
Hopefully this issue can be resolved, thank you for your time.
Christopher
5 REPLIES 5
sefe
Hi
I would delete the Maya preferences in the documents folder and relaunch Maya.
If that doesn't work, check to see if you have the latest Open Gl and DirectX updates.
If all fails then set some of the settings in your preferences window to legacy; such as render setup.
Hope this helps
in reply to: sefe
Thanks for your response. I uninstalled maya 2019 and reinstalled the 2018.5 version to see if it would work and the same problem continues. However, when I uninstall my nvidia driver the program opens without freezing. I couldn't install OpenGL with my version of windows. How do I change my preferences window to legacy?
sefe
Try these
in reply to: sefe
thank you!! this helped.
Was having same type of issue, following the steps mentioned above helped me.
Big Thanks
