Maya crashes when using undo command
eddy.loukil46CZX
Observer Observer
eddy.loukil46CZX
Observer
Observer
When using ctrl+z to undo in Maya it will crash 9 times out of 10, on every single scene, regardless of complexity. Sometimes after a couple, sometimes after a dozen.
I am using maya 2023 and have a already tried doing a fresh re-install and resetting the prefs folder with no avail.
Someone can help ?
Crash log attached to that topic.
Thank you.
navya_gelli
Hi @eddy.loukil46CZX ,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Navya | Community Manager
