Hello, can anyone suggest a workaround for a Maya 2024 not starting up on a Fresh install Win11 Pro (Amd Ryzen 9, RTX 4080, 128 GB RAM, m.2 SSD).
Error message below:
Date/Time: 2024-02-08 11:58:59 +00:00
Application: maya.exe
Error: Access violation - code c0000005 (first/second chance not available)
Crashed Module Name: python310.dll
Exception Address: 0x00007ff86b97ac87
Exception Code: c0000005
Exception Flags: 0
Exception Parameters: 0, 8
Solved by ricardoviana. Go to Solution.
Hi. I am having a similar problem. Maya 2024.2 was working great, then a day or two ago, it started failing on launch.
Maya startup has "license verified", then goes to starting and crashes. I have been using 2024 since it came out and this is the first time this has happened.
error message:
Date/Time: 2024-02-12 07:28:58 -05:00
Crashed Module Name: ArubaModelBase.dll
Exception Address: 0x00007ffbdd931a00
My computer:
Windows 10 Home 64-bit
Intel Core i9 9900K @ 3.60GHz
4095MB NVIDIA GeForce RTX 2080 SUPER (MSI)
128GB Dual-Channel DDR4 @ 1600MHz (16-20-20-38)
Fresh install of Python 3.11 and deleted a wrong PYTHONPATH environment variable, did the trick.
