- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
macbook pro 2019 i 9 9980hk 5500m 8gb MacOS sonoma and sequoia
maya 2024 and 2025
i had maya 2025 installed and clicked open, it just bounced up and down and didnt open so i tried using the terminal to open maya it retuned:
/Applications/Autodesk/maya2025/Maya.app/Contents/MacOS/Maya ; exit;
user@Oscars-Macbook-Pro ~ % /Applications/Autodesk/maya2025/Maya.app/Contents/MacOS/Maya ; exit;
maya: Autodesk MAYA 2025
A licensing error occurred that Autodesk systems were not able to handle for you. Please contact Autodesk Customer Support for help in resolving this error.
adlsdkAuthorize returned with error code: ADLSDK_STATUS_LICENSE_CHECKOUT_ERROR
The default location for log files to help diagnose the issue is:
"/var/folders/87/kp5lkv293p7ff9drfwj7yrtw0000gn/T/MayaCLM-10-10-2024.log"
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
so i made sure ADLS was installed, it was but to make sure, i deleted it and reinstalled the latest version, still returned the same error so i deleted maya and any autodesk/maya/adls/adlm file i found in macoOS library and reinstalled maya and ADLS and it still gave the same error.
i updated macos to macos sequioa and downgraded maya to 2024 but i still got the error.
i have no idea what else to do so any help or ideas would be appreciated.
the log file is attached below.
