Maya 2022 - Sign In button is over File and Edit menu - how to remove it?
panan_victory
panan_victory
Hi there,
There is a Sign In button floating over the File and Edit menu, I can't remove it. Could you please advise how to remove it?
Thanks very much.
panan_victory
Found a solution in another post.
jdanielsZDSGU
Observer
Observer
I'm also having this issue. Can you link to where you found the solution in another post? Or post the answer here?  Unless I'm missing something I don't see a solution on this thread or an external link. Thanks!
jdanielsZDSGU
Observer
Observer
Ah, found it!  For anyone else who has this issue, here's the solution that worked for me:
https://forums.autodesk.com/t5/maya-forum/after-update-maya-2022-the-window-with-licence-information...
I also ran into this problem and after poking around, was able to fix it by deleting my auto-saved workspaces by closing maya then deleting all the .json files in Documents\maya\2022\prefs\workspaces.  I'm guessing the auto-save functionality at some point corrupted the workspace layout or something!
rl3426VB8JR
Close your Maya program and reopen it. It will solve the issue.
yesupatham1
Community Visitor
Community Visitor
It worked. Thank you!
