Maya 2020 doesn't open/crashes on startup - Mac
Message 1 of 19
Hi
I installed 2020 (Edu) on MacOS 10.13.6 and it crashed at the splash screen stage, saying it saved a .ma scene file (which I never found).
I also had 2019 which worked fine.
I tried reinstalling 2020, nothing changed, same crash on splash screen.
I then removed everything, 2019, 2020, license manager and all and reinstalled only 2020.
And now it doesn't even get to the splash screen. The icon bounces a few times on the dock and disappears. I can't even type my serial number.
Is there a log somewhere explaining what's going wrong?
Thanks.
Replies (18)
Message 2 of 19
Mark.Lancaster
@Anonymous
Your posting is 2 weeks old without any response from anybody.  Do you still need assistance on this issue or has it been resolved?
Mark Lancaster
Message 3 of 19
No I still very much need assistance.
Message 4 of 19
I am also having the same problem as well. I uninstalled and reinstalled Maya 2020. My icon is bouncing but it does not open the activation page so I am not sure what going on but if someone can help solve this problem that would be great. I am also using macOS Catalina 10.15.2.
Message 5 of 19
Same here...LMU crashes. Maya 2020 Mac OS Catalina iMac Late 2013 Core i7.
Message 6 of 19
gormanj
Observer
Observer
Same here.
Message 7 of 19
Same problem.  Lab full of Macs running 10.14, Maya 2020.
Application bounces, does not start.  Some did for a day or two, and then stopped working.
Tried manually uninstalling...one machine starts now, others don't.  What's the secret?
Message 8 of 19
Please solve this problem it's so annoying, all happened after installing the newestOS...
Message 9 of 19
I installed 2020 while I still had 2019 and the old 2016 installed and it was working fine. When I uninstalled the older versions, I get bouncy icon for 2020 and nothing else happens...
Message 10 of 19
Good news, Maya 2020.1 works!
Message 11 of 19
how u fix it?
my email
[email protected]
Message 12 of 19
gormanj
Observer
Observer
Maya doesn't seem to like multiple versions or authorizations any more. I think I needed to delete the licenses, preferences and install again. On a mac, the license is in an invisible folder /Library/Application Support/Autodesk/Adlm/.config/ProductInformation.pit. .config is the invisible folder. Shift-Command-period will hide or show invisible items. Perform at your own risk.
Message 13 of 19
I delete Maya from application folder, delete the license, /Library/Application Support/Autodesk/Adlm/.config/ProductInformation.pit.
but still doesn't work, just bounce and close.
Message 14 of 19
rsorom
I'm also having this exact same issue but my laptop is up to date. Did you ever find a solution to fix this issue?
Message 15 of 19
I have the same issue and none of the solutions have worked. I manually delete the HIDDEN .pit file and still Maya 2020 will not open after a freash install. This is really bad I have labs of over 150 Macs I need this working on. What is going on? And why am I having to do any of this just to get Maya 2020 re-installed? All I get in a few bounces on the dock and then nothing. Please help AutoDesk!
Message 16 of 19
Hello rsorom, no i haven't figured a way to solve the problem, and gave up
on it because of the new strict rules 🙂
Message 17 of 19
My fellas, I had the same issue, I have installed Maya 2020 with macOS Big Sur 11.2.3 and worked fine but I decided to upgrade to Maya 2020.4, and the problems starte, Maya doesnt open just bounce and close. So I tried to install the 2020 again but the problem was the same, the I try 2020.1, 2020.2 and the problem still ! then I tried 2019, even 2018 and the Maya opens but crashes so doesn't work for me. So I decide to restart my Mac and retry to install Maya 2020 and finally works.
-So my tips are !
Check this page to make a clean uninstall.
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Clean-uninstall-of-Autod...
also delete the Autodesk folder in /Users/Shared
-Restart your Mac
-Use the 2020 version or the one that previously works with you !
I hope this can help you !
Message 18 of 19
I have same problem in Catalina 10.15.04
Message 19 of 19
Hey, try to use Maya 2019 or even 2018, my friends have catalina with Maya 2018 works fine for them !
