Maya 2020.1 broken and useless (bug report filed)
Don't update to Maya 2020.1.
The Device/Pixel aspect ratio in Render Settings is broken. Pixel is set to 1000 and you can't change it to 1.
Worst: If you try to change it to 1 it will change Device to 1777.778 and you can't change this anymore.
This will cause that Arnold isn't able to render the picture in the correct format anymore.
Arnold is able to deal with this as long as you don't trouch the Pixel aspect ratio.
Redshift can't handle it completely. When you just open the Render Settings without changing anything the Render View shows a single line due to the Pixel aspect ratio of 1000. If I try to change the display settings in Redshift Render View to "Fill Window" Maya will crash.
I have filed a bug report rated CRITICAL to Autodesk today.
