Maya 2020.1 broken and useless (bug report filed)
3dvfxprofessor
Message 1 of 11
3dvfxprofessor
Don't update to Maya 2020.1.
The Device/Pixel aspect ratio in Render Settings is broken. Pixel is set to 1000 and you can't change it to 1.
Worst: If you try to change it to 1 it will change Device to 1777.778 and you can't change this anymore.
This will cause that Arnold isn't able to render the picture in the correct format anymore.
Arnold is able to deal with this as long as you don't trouch the Pixel aspect ratio.
Redshift can't handle it completely. When you just open the Render Settings without changing anything the Render View shows a single line due to the Pixel aspect ratio of 1000. If I try to change the display settings in Redshift Render View to "Fill Window" Maya will crash.
I have filed a bug report rated CRITICAL to Autodesk today.
200417_Maya_2020.1_Render_Settings_Bug.png200417_Maya_2020.1_Render_Settings_Bug_Edited.png200417_Maya_2020.1_Render_View_Crash.png200417_Maya_2020.1_Render_View_Broken.png
Replies (10)
Message 2 of 11
mspeer
Hi!
This is a known issue, but there is a workaround:
https://forums.autodesk.com/t5/maya-forum/maya-2020-1-input-values-1000/td-p/9397931
Message 3 of 11
3dvfxprofessor
In my case it doesn't work. The aspect value has to be set to 1. I can't fix this with any method. Even editing the .ma file will not help here because the value will always be set to 1000.000 and finally 1777.778.
Message 4 of 11
mspeer
Hi!
Please try to change your complete region / language .
(Switch to an English format / Setup)
This is for sure a region / language specific problem and the workaround was confirmed to work, by others.
Please (re)start Maya AFTER you changed the settings.
Message 5 of 11
3dvfxprofessor
This works. Thanks. But you need just to change the regional settings for date/time. This seems to affect the number formats over all kind of applications like Excel where my dates are changed from 18.05.2020 to 20/05/18 now. 😉
Message 6 of 11
lennart.oberscheidt
Use the environment variable as suggested in the other thread, works for us. This doesn't require you to change the language settings, which, of course, you wouldn't want to touch just to get maya running as other programs depend on that as well.
MAYA_FORCE_C_LOCALE=1
However, what I don't understand is why Autodesk doesn't sticky a post on these forums detailing the (temporary) solution! After all, this IS a critical bug (and only easily work-arounded IF you happen to know how…). Also, it'd be easy to put into the 2020.1 release notes asap.
Literally everyone I know, because I'm living in europe, is faced with this bug after updating to 2020.1. There is  literally NO way this hasn't come up during beta testing, because you are confronted with this basically 10 to 60 seconds after opening 2020.1.
Message 7 of 11
ray
Didn't 2020.2 solve the problem ?
Message 8 of 11
3dvfxprofessor
I installed 2020.2 a few days ago and had to set the environment variable again to fix it.
Message 9 of 11
ray
Message 10 of 11
ray
2020.3 is out, anyone knows if the bug was fixed ?
Message 11 of 11
mspeer
Hi!
This is fixed in Maya 2020.3 .
(At least it's stated as fixed.)
I have not tested this for now.
