MAYA 2019: Unit size / Grid Size issue
Hello!
Normally when I choose my unit size in preferences, the grid size would reflect those changes (if its inches, one square on the grid would be 1 inch)
In Maya 2019
right now... it doesn't look like that. I have set to inches and and its several units in size.
sean.heasley
Hi @Anonymous
What are your grid settings?
Changing to from cm to inches will affect the grid but it wont automatically make one grid unit equal 6inches or 12 inches for example.
You need to manually change the grid values to match with what you want.
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
