Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
MAYA 2019.2 AND XGEN ISSUE IN BATCH RENDER
2 REPLIES 2
767 Views, 2 Replies
I have recently updated to maya 2019.2 and everything was working great but i run into an issue while using xgen
i have a scene which was fine in earlier version of maya but now when i use it in maya 2019 my groom renders fine in the arnold render view and in scene file also i checked the hair is following the geometry properly but when i do a batch render locally or on a render farm the hair is fine in 1st frame but as the animation progresses the hair seems to leave the mesh.
i have maya 2019.2 with arnold 3.3.0
windows 10
and i have tried the following steps.
    exported the groom and imported it into a new clean file
    i exported the patches from maya 2016 and replaced it (as it was rendering fine in maya 2016)
    exported curves and did a new groom in maya 2019
    changing fps of the scene as mentioned in this post (https://forums.autodesk.com/t5/maya-forum/maya-2019-xgen-trouble-at-render-time/td-p/8769538)
and this issue can be reproduced easily
     i tried everything i can think of please let me know if i am missing something
    please help me out if anyone  faced this.
  i have attached an image for you to see
     thanks in advance !!
Regards
Harsh
2 REPLIES 2
I am facing the same issue...did you find any solution?
Yes and no. , Had a long conversation with autodesk and they said it will be fixed in next version that is 2020, so I rolled back to 2018
Althoug 2018 has some issues in render setup but still quiet stable , I hope this helps
