Before, when I was using the node editor Maya fand a way to arrange all the node nicely.
Now, it puts all the nodes in a superposed model, which is quite tiring to expand one by one.
Just tell me I am wrong, and there is an option to uncheck.
Please.
Thx
Fransua
Solved by mspeer. Go to Solution.
Hi!
Is "Pin all nodes by default" active?
The problem is that Maya creates nodes at the center first and then arranges them in a second step.
Actually yes, "Pin all nodes by default" was active.
But when I unchecked it and create a new tab in the node editor, it goes back on checked mode by default.
Hi!
This setting will not be saved in the scene, every time you open the Node Editor
the setting from the Preferences will be used.
