Maya 2018 // Error: line 1: Cannot find procedure "createBlendShapePanelMenu". //
adnanmg
adnanmg
running Maya 2018 on Win 10 64 bit, I'm getting this error when I load a file with blendshapes that was created in 2018 also.
It just comes up every time, maybe once for each blendshape in the scene , then pops up the blendshape panel and the scene loads fine, but it takes a much longer time, going through all of those errors. Any idea what's up?
Thank you,
Adnan
Replies (8)
adnanmg
I reinstalled maya, then I got the attached error. It is a syntax error. Once I fix it, I get the Re: Maya 2018 // Error: line 1: Cannot find procedure "createBlendShapePanelMenu". //
Any ideas? I don't even need that panel menu...! I just need my files to load faster.
Adnan
adnanmg
With the syntax error fixed (strange that it had a syntax error), it still takes a long time to load the file (without errors now), but for each blendshape it flashes the blendshape panel window...Has anyone else experienced this and found a fix?
Adnan
adnanmg
sorry, here is the file. it failed to upload previously.
mspeer
Hi!
The problem has nothing to do with your Maya version or with BlendShapes in general.
The  problem is a totally messed up scene-file.
There are about
- 500 similar script nodes that get executed when loading your scene.
Example (that's your flicker):
if(`window -exists bpWindow`){deleteUI bpWindow;}; window -rtf 0 -title \"Blend Shapes\" bpWindow;frameLayout -lv 0;blendShapePanel;window -edit -widthHeight 250 350 -tlc 200 200 bpWindow; showWindow bpWindow;";
- 6600 renderLayerManager nodes
...and more.
I recommend to clean up the scene, then the problem is gone.
adnanmg
Phew. That is a relief. Thanks for taking a look. How do I remove that? I tried optimize scene size, but that did not do it.
Thanks so much!
Adnan
mspeer
Hi!
You could use a custom script to check and remove certain nodes
or remove them manually by using the Outliner:
- Display -> DAG Objects only (uncheck)
- Show -> Show Auxiliary Objects (check)
or other editors like Namespace Editor (you also have more than 750 Namespaces in your scene).
mspeer
Hi!
What you also can try is to select only what you want to keep and export this as a new file.
adnanmg
Thanks so much for your help. I was working on deleting nodes and then reloading to check. Since all the unneeded nodes are just junk nodes, not connected to anything I need, saving selected just now after reading that suggestion did the trick. That saves me a lot of headache. Thanks!
Adnan
