Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya 2018 destroyed all incremental saves from one day?
7 REPLIES 7
Message 1 of 8
4345 Views, 7 Replies
X post from Programming, figured I would try my luck with a broader forum post too.
Alright so I had to postpone my madness as I think the data might still be here but I have no idea if I have to do it all over again or if it can be recovered (fingers crossed)
I have attached the file if anyone can take a look, I have prior backups but I got a ton of work done on one day and even my incremental saves are corrupt from that day.
https://drive.google.com/open?id=1PX7LtI7pyaaTMu32KCxWwVqJxguTdM-y
Please, if anyone has any way of recovering this data you would be my saviour!
This is the error message I get on load
file -f -new;
// Warning: file: E:/Autodesk/Maya2018/scripts/startup/rememberViewportSettings.mel line 29: Active stereo does not work with Aero enabled. Active stereo has been disabled. //
// untitled //
commandPort -securityWarning -name commandportDefault;
onSetCurrentLayout "Maya Classic";
// AbcExport v1.0 using Alembic 1.5.8 (built Jul 13 2016 18:28:45)
// AbcImport v1.0 using Alembic 1.5.8 (built Jul 13 2016 18:28:45)
# pymel.core : Updating pymel with pre-loaded plugins: mayaHIK, GamePipeline, CloudImportExport, tiffFloatReader, bifrostvisplugin, ikSpringSolver, ik2Bsolver, xgenToolkit, AbcExport, retargeterNodes, gameFbxExporter, VectorRender, OpenEXRLoader, lookdevKit, Unfold3D, Type, mayaCharacterization, modelingToolkit, MayaMuscle, rotateHelper, matrixNodes, bifmeshio, AbcImport, deformerEvaluator, autoLoader, sceneAssembly, gpuCache, Substance, OneClick, shaderFXPlugin, bifrostshellnode, renderSetup, GPUBuiltInDeformer, ArubaTessellator, quatNodes, fbxmaya
evalDeferred "shaderBallRendererMenuUpdate";
import arnold
// Successfully imported python module 'arnold'
import mtoa
// Successfully imported python module 'mtoa'
import mtoa.cmds.registerArnoldRenderer;mtoa.cmds.registerArnoldRenderer.registerArnoldRenderer()
Maya 2018 importing module pymel 1.0.10 (E:\Autodesk\Maya2018\Python\lib\site-packages\pymel\__init__.pyc)
// Successfully registered renderer 'arnold'
// Warning: file: E:/Autodesk/Maya2018/scripts/startup/autoLoadPlugin.mel line 35: Loading plug-in "mtoa" has resulted in changes to the scene that may need to be saved. //
updateRendererUI;
updateRendererUI;
file -f -options "v=0;p=17;f=0" -ignoreVersion -typ "mayaAscii" -o "D:/3d projects/Haunt in bangalore/Maya/Blockout_01_02.0007.ma";addRecentFile("D:/3d projects/Haunt in bangalore/Maya/Blockout_01_02.0007.ma", "mayaAscii");
closeAllNodeEditors;
closeHypershade;
updateRenderOverride;
// Error: setAttr ".uvtk[2]" -type "float2" -nan(ind) -nan(ind) ; //
// Error: "D:/3d projects/Haunt in bangalore/Maya/Blockout_01_02.0007.ma" line 252156.44: Invalid use of Maya object "ind". //
// Error: "D:/3d projects/Haunt in bangalore/Maya/Blockout_01_02.0007.ma" line 252156.54: Invalid use of Maya object "ind". //
// Error: setAttr ".uvtk[9]" -type "float2" -nan(ind) -nan(ind) ; //
// Error: "D:/3d projects/Haunt in bangalore/Maya/Blockout_01_02.0007.ma" line 252157.44: Invalid use of Maya object "ind". //
// Error: "D:/3d projects/Haunt in bangalore/Maya/Blockout_01_02.0007.ma" line 252157.54: Invalid use of Maya object "ind". //
// Error: setAttr ".uvtk[7]" -type "float2" -nan(ind) -nan(ind) ; //
// Error: "D:/3d projects/Haunt in bangalore/Maya/Blockout_01_02.0007.ma" line 252174.44: Invalid use of Maya object "ind". //
// Error: "D:/3d projects/Haunt in bangalore/Maya/Blockout_01_02.0007.ma" line 252174.54: Invalid use of Maya object "ind". //
// Error: setAttr ".uvtk[18]" -type "float2" -nan(ind) -nan(ind) ; //
// Error: "D:/3d projects/Haunt in bangalore/Maya/Blockout_01_02.0007.ma" line 252175.45: Invalid use of Maya object "ind". //
// Error: "D:/3d projects/Haunt in bangalore/Maya/Blockout_01_02.0007.ma" line 252175.55: Invalid use of Maya object "ind". //
// Error: setAttr ".uvtk[4]" -type "float2" -nan(ind) -nan(ind) ; //
// Error: "D:/3d projects/Haunt in bangalore/Maya/Blockout_01_02.0007.ma" line 252191.44: Invalid use of Maya object "ind". //
// Error: "D:/3d projects/Haunt in bangalore/Maya/Blockout_01_02.0007.ma" line 252191.54: Invalid use of Maya object "ind". //
// Error: setAttr ".uvtk[1]" -type "float2" -nan(ind) -nan(ind) ; //
// Error: "D:/3d projects/Haunt in bangalore/Maya/Blockout_01_02.0007.ma" line 252208.44: Invalid use of Maya object "ind". //
// Error: "D:/3d projects/Haunt in bangalore/Maya/Blockout_01_02.0007.ma" line 252208.54: Invalid use of Maya object "ind". //
// Error: connectAttr "polyUnite4.out" "groupParts57.ig"; //
// Error: "D:/3d projects/Haunt in bangalore/Maya/Blockout_01_02.0007.ma" line 258734.11: Syntax error //
// File read in 3.4 seconds.
7 REPLIES 7
Message 2 of 8
mspeer
Hi!
Open the scene-file (.ma) with a Text Editor and replace every
-nan(ind)
with
0
(BTW, the scene opens here with Maya 2018.2 even without this correction, so you might update your Maya).
Message 3 of 8
in reply to: mspeer
Thanks! That worked like a charm!
Message 4 of 8
in reply to: mspeer
you saved me
Message 5 of 8
sean
in reply to: mspeer
I also had this happen to me... all my incremental saves for an entire day were corrupted. This fixed it! This was in Maya 2018.4. This seems like a VERY SERIOUS bug... I hope someone at Autodesk is looking into this corruption of files! Not good. I was convinced that I had lost all my work for the day. Thank you for this fix though. I wish I knew what caused it... so that I can avoid it in the future. Any ideas?
Message 6 of 8
in reply to: mspeer
Good god man!! Thank you! Saved me from a world of headache..
Message 7 of 8
in reply to: mspeer
Awesome !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You are my god. It's solved my problems.
Message 8 of 8
Can this error be fixed following the same procedure?
// Error: setAttr ".uvst[0].uvsp[500:550]" 0.71650636 0.125 0.625 0.033493653 0.5 0 0.375 //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 31410.52: Invalid use of Maya object "ind". //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 31410.62: Invalid use of Maya object "ind". //
// Error: setAttr ".fc[1000:1499]" //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 39539.8: Syntax error //
// Error: setAttr ".fc[2500:2999]" //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 50489.8: Syntax error //
// Error: setAttr ".vt[12450:12615]" -272.23110962 314.90878296 465.48532104 272.2310791 314.90878296 465.48532104 //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 56355.8: Syntax error //
// Error: setAttr ".vt[25398:25563]" 159.56239319 673.78875732 96.23065948 -168.36331177 665.81396484 94.44872284 //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 60893.8: Syntax error //
// Error: setAttr ".vt[38346:38511]" -70.1101532 726.75445557 -249.72645569 69.94714355 726.74871826 -249.72810364 //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 65744.8: Syntax error //
// Error: setAttr ".vt[50962:51127]" 280.14736938 483.96551514 -581.62805176 -281.32061768 476.95001221 -581.63592529 //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 71014.8: Syntax error //
// Error: setAttr ".vt[63578:63743]" 286.088684082 300.80801392 -884.82733154 -285.26724243 294.15631104 -884.80224609 //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 76251.8: Syntax error //
// Error: setAttr ".vt[76028:76193]" 278.13867188 483.36621094 -1104.2713623 -279.45742798 476.28082275 -1104.29003906 //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 81728.8: Syntax error //
// Error: setAttr ".vt[88312:88477]" 285.63977051 420.83642578 -1356.19433594 -285.71530151 411.70269775 -1356.16931152 //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 87556.8: Syntax error //
// Error: setAttr ".vt[100430:100595]" 39.15419006 658.85498047 -1757.31323242 46.19836807 658.2277832 -1757.30371094 //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 93293.8: Syntax error //
// Error: setAttr ".ed[20086:20251]" 10015 10016 0 10016 9793 0 10016 10017 0 10017 9794 0 //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 99169.8: Syntax error //
// Error: setAttr ".ed[55942:56107]" 27928 27666 0 27928 27929 0 27929 27667 0 27929 27930 0 //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 105217.8: Syntax error //
// Error: setAttr ".ed[91632:91797]" 45765 45499 0 45765 45766 0 45766 45500 0 45766 45767 0 //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 111237.8: Syntax error //
// Error: setAttr ".ed[127322:127487]" 63623 63627 0 63627 63239 0 63240 63628 0 63628 63624 0 //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 117257.8: Syntax error //
// Error: setAttr ".ed[163012:163177]" 81481 81482 0 81482 81063 0 81482 81487 0 81487 81064 0 //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 123277.8: Syntax error //
// Error: setAttr ".ed[198868:199033]" 99277 99106 0 99277 99278 0 99278 99107 0 99278 99279 0 //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 129325.8: Syntax error //
// Error: setAttr ".fc[9000:9499]" //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 140980.8: Syntax error //
// Error: setAttr ".fc[25000:25499]" //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 157012.8: Syntax error //
// Error: setAttr ".fc[41500:41999]" //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 173545.8: Syntax error //
// Error: setAttr ".fc[57000:57499]" //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 189076.8: Syntax error //
// Error: setAttr ".fc[71500:71999]" //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 203605.8: Syntax error //
// Error: setAttr ".fc[86000:86499]" //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 218134.8: Syntax error //
// Error: setAttr ".fc[100500:100999]" //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 232663.8: Syntax error //
// Error: setAttr ".fc[1000:1439]" //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 245010.8: Syntax error //
// Error: setAttr ".pt[1328:1493]" -12.86302 0.46441853 2.6698017 -12.862399 0.46300524 //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 254972.8: Syntax error //
// Error: setAttr ".fc[0:499]" -type "polyFaces" //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 264336.8: Syntax error //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 275305.8: Syntax error //
// Error: setAttr ".ed[3486:3651]" 1765 1764 1 1761 1793 1 1766 1754 1 1766 1762 1 1767 1779 1 //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 284162.8: Syntax error //
// Error: setAttr ".uvst[0].uvsp[2250:2499]" 0.49932298 4.0583095e-07 0.5 0.49932301 0.49990404 //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 296597.8: Syntax error //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 305749.8: Syntax error //
// Error: setAttr ".ed[1826:1991]" 925 938 1 925 924 1 924 939 1 939 938 1 927 926 1 926 941 1 //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 317020.8: Syntax error //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 327957.8: Syntax error //
// Error: setAttr ".hfd" -type "dataPolyComponent" Index_Data Face 0 ; //
// Error: "D:/Work/Test/Prasad LLP/GoW-Vulture_Test/scenes/Vulture_Blockout_05.ma" line 340380.8: Syntax error //
// Warning: line 0: swatches file depend node not found, icon discarded: phong1 //
// Warning: line 0: swatches file depend node not found, icon discarded: HumanBody:blinn1 //
