Announcements
MAya 2018 can't move rotate or scale.
Hi i am trying to move my object and i cant seem to click the arrows/pivot points instead it just selects an area and i have this problem with the rotation and the scale tool as well . please help me fix it.
Hi @Anonymous your title 'CANT MOVE PIVOT POINT' was edited for clarity by @sean.heasley
sean.heasley
Hi @Anonymous and welcome to the community!
Try deleting your settings/preferences.
If that doesn't work, check your GPU driver and make sure it matches our certified hardware list.
You can find our certified hardware list here!
Let me know if anything changes!
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
