Maya 2018 and 2019 Freezing up on launch
Hello, all!
This is my first post on these forums and, sadly, it's due to a problem.
I'd been using Maya just fine after upgrading my pc and reinstalling Windows 10, but now, overnight, I'm unable to get any work done.
I've attached screenshots.
Thank you!
sean.heasley
Hi @Anonymous
This is probably a GPU issue. What driver version are you using for your 2070? Please make sure you're using the same version as our certified hardware list.
You can find our certified hardware list here!
You can also try deleting your settings/preferences.
Please let me know if anything changes!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
You're a lifesaver!
Resetting the prefs folder did it! I am using an unsupported driver version of my GPU though. Maya 2018 was working fine for the longest time and it apparently doesn't support my 2070 at all.
Regardless, thank you!
sean.heasley
Hi @Anonymous
No problem glad it worked for you!
