Is there a silent installer (via a parameter or release) on Windows for Maya updates? The current default run exe needs user input.
Thank you.
Solved by cornelh. Go to Solution.
let me know if that helps.. yet there is not other installer to answer your first question..
Good luck.
yes this works for me with Maya 2017 update 2. My install line is :
"\\Myserver\APPS\MAYA_2017\SPs\Autodesk_Maya_2017_Update2_x64.exe" /quiet
Many thanks,
F.
