- Mute
- Permalink
- Report
I have a piece of code which opens a window with a button, and this button has popup menu attached. It works in Maya 2016. But on Maya 2017, buttons menu doesn't show. Question, why?
The code:
# -*- coding: utf-8 -*- try: from PySide.QtCore import * from PySide.QtGui import * from shiboken import wrapInstance except ImportError: from PySide2.QtCore import * from PySide2.QtGui import * from PySide2.QtWidgets import * from shiboken2 import wrapInstance from functools import partial from maya import OpenMayaUI as omui import maya.cmds as cmds def getMayaWindow(): try: mayaMainWindowPtr = omui.MQtUtil.mainWindow() mayaMainWindow = wrapInstance(long(mayaMainWindowPtr), QWidget) except: mayaMainWindow = None return mayaMainWindow class ContextQuadMenuUI(object): def setupUi(self, Dialog): Dialog.setObjectName("Dialog") Dialog.resize(149, 97) self.horizontalLayout = QHBoxLayout(Dialog) self.horizontalLayout.setSpacing(0) self.horizontalLayout.setContentsMargins(0, 0, 0, 0) self.horizontalLayout.setObjectName("horizontalLayout") return class ContextQuadMenu(QDialog): def __init__(self, parent=getMayaWindow()): if cmds.window('tmkContextQuadMenu', exists=True): cmds.deleteUI('tmkContextQuadMenu', window=True) wnd = cmds.window('tmkContextQuadMenu') ptr = omui.MQtUtil.findControl( wnd ) wdg = wrapInstance(long(ptr), QWidget) super(ContextQuadMenu, self).__init__(wdg) self.ui = ContextQuadMenuUI() self.ui.setupUi(self) self.setAttribute(Qt.WA_DeleteOnClose) mymenu = QMenu() mymenu.addAction("item") newbutton = QToolButton() newbutton.setAutoRaise(True) newbutton.setText("blah") newbutton.setMenu(mymenu) newbutton.setPopupMode(QToolButton.InstantPopup) self.ui.horizontalLayout.addWidget(newbutton) self.show() ContextQuadMenu()
What am I doing wrong? Is it Qt5 which makes the difference?
