AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
Maya 2015 Startup Error: Python Conflicting
jazioblaq
Message 1 of 8
jazioblaq
Hello group, I have been searching for a solution for this python conflicting problem. I am not a programmer and do not know what any of this means. I can render a still image but if I want to do a batch render, I get a python 'conflict with this version of python as well as when I start Maya;
Here is the error:
# Error: file: C:/Program Files/Autodesk/Maya2015/plug-ins/xgen/scripts/igInitialize.mel line 63: ImportError: file C:\Program Files\Autodesk\Maya2015\bin\python27.zip\ctypes\__init__.py line 10: Module use of python34.dll conflicts with this version of Python. #
// Error: Unable to execute igInitialize.mel. //
# Error: line 0: ImportError: file C:\Program Files\Autodesk\Maya2015\bin\python27.zip\ctypes\__init__.py line 10: Module use of python34.dll conflicts with this version of Python. #
// Error: Unable to execute xgen.mel. //
updateRendererUI;
# Error: file: C:/Program Files/Autodesk/Maya2015/plug-ins/xgen/scripts/xgenUI.mel line 140: NameError: file <maya console> line 1: name 'xg' is not defined #
somebody please help!
Replies (7)
Message 2 of 8
warnold2
Maya has an embedded version of Python 2.7.x. are you setting any environment variables which would direct Maya to use the wrong version, possibly system installed versions
Check for PYTHONHOME and/or PYTHONPATH
What do you have in your PATH variable
Wayne Arnold
Developer
Message 3 of 8
jazioblaq
Hello and thanks for you reply.
How do I check the  PYTHONHOME and/or PYTHONPATH?
This is what I have for PATH
C:\Program Files (x86)\iis express\PHP\v5.4;
C:\ProgramData\Oracle\Java\javapath;
C:\Windows\system32;
C:\Windows;
C:\Windows\System32\Wbem;
C:\Windows\System32\WindowsPowerShell\v1.0\;
C:\Program Files\Hewlett-Packard\SimplePass\;
C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;
C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;
C:\Program Files (x86)\Microsoft SDKs\TypeScript\1.0\;
C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;
C:\Program Files\Microsoft SQL Server\120\Tools\Binn\;
C:\Program Files (x86)\GtkSharp\2.12\bin;
C:\Program Files\Java\jdk1.8.0_31\bin;
C:\Users\Michael\AppData\Local\Android\android-sdk\tools;
C:\Users\Michael\AppData\Local\Android\android-sdk\platform-tools;
C:\apache-ant-1.9.3\bin;
C:\Program Files (x86)\nodejs\;
C:\Program Files (x86)\Git\cmd;
C:\Program Files\Microsoft\Web Platform Installer\;
C:\Users\Michael\AppData\Roaming\npm;
C:\Python27;
Message 4 of 8
warnold2
They are environment variables
From a cmd shell you can list all environment variables with the command: set
Or right click on MyComputer ->properties->advanced->environment variables
Looks like you also have Python 2.7 installed, it's in your PATH. this may or may not be problematic if it's 64bit and there is a python27.dll in c:\windows\system32. If it's found before Maya's version. Though the error would be different than the one you reported
Wayne Arnold
Developer
Message 5 of 8
jazioblaq
OK! I found the other paths:
PSModulePath
%SystemRoot%\system32\WindowsPowerShell\v1.0\Modules\
PYTHON_HOME
C:\Python34;
Yes I do have Python 2.7 and 3.4  .dll's in my system32 folder.
Do I need to take something out or set something different?
Message 6 of 8
warnold2
I was expecting PYTHONHOME without the underscore but I would try deleting that variable
Then try to restart Maya. One needs to ensure that variable is not set when starting Maya
Or create a batch file that unsets the variable, then starts Maya
set PYTHONHOME=
"C:\Program Files\Autodesk\maya2015\bin\maya.exe"
Wayne Arnold
Developer
Message 7 of 8
jazioblaq
Ok, I deleted the PYTHON_HOME, restarted Maya and got the same error.
Im sorry, I have no clue how to create / set a batch file.
Message 8 of 8
Set the environment variables PYTHONHOME=C:/where/maya.exe PYTHONPAHT=C:/wherepithon.exeis/ good look
