Maya 2015 SP6 Isolate Select Crash
Hey there!
I've submitted this bug report for this issue several times but I'm starting to wonder if this is an issue I can fix on my end.
The problem is when I'm in Maya and Isolating an object or any geometric element using the Isolation viewport mode then try to edit the verts/edges in any way, the program crashes. This has happened while using the multi-cut tool, merging verts together, and even simply moving verts. While moving, it seems to crash more consistently while using the dual axis transform handles; the handles that let you slide along two axis at the same time.
Here are my software and hardware versions. Let me know if you need anymore information!
Maya 2015 SP6
Windows 10 Home 64-bit
Intel Core i7-4771 CPU @ 3.50GHz (8 CPUs)
NVIDIA GeForce GTX 760
Thank you!
Thank you!
