match pivot question
HeavyMetalFox
HeavyMetalFox
Is there a way to match the pivot orientation and position of two objects if if they are not at the same place?
It seems that the only way to make the "match pivot" tool work, is for the two objects to be at the same placea5.jpg.
brentmc
Dumb question but did you set the Match Pivot Options to just match orientation?
Brent McPherson
Principle Software Developer
HeavyMetalFox
Hey Brent 🙂
Yes I did try all the options.
Even if I check only this option, the tool will displace the pivot to the position of object A.
brentmc
Can you provide  a simple Maya ascii file (.ma) that shows the issue?
Thanks.
Brent McPherson
HeavyMetalFox
Hey Brent,
Sorry for the late reply, been pretty busy.
I created a new scene and everything worked correctly.
Thanks alot for your help.
brentmc
Glad it is working. Thanks for the update.
Brent McPherson
