Hello friends,
I'm relatively new to Maya (3 days in), but extremely eager to learn every aspect of the program and start creating short films or be able to call myself "Maya Proficient" for CGI internships.
Unfortunately, I’ve run into a problem that is causing Maya to be almost unusable for me.
Tumbling, selecting, or toggling viewports through the spacebar causes Maya to freeze for anywhere between 6-15 seconds before the command I issued appears.
This does NOT occur when in simple projects (and by “simple”, I mean like 2 or 3 cubes and random floating joints – 3days in people 😛 ), but is constantly coming up in a Solar Panel project I’ve begun to create.
My first thought was that my computer specs were just too weak to handle this professional grade software, but other people seem to be running it on laptops or various toasters without a problem.
Here are my computer specs.
I've attached the actual file of the Solar Panel I'm in the process of creating below - in case that doesnt work, or you don't want to spend a few minutes downloading and opening a Maya file, here's a couple screenshots of what I'm looking at and is causing the lag.
It is most noticable when I select the panels as a whole, grouped in the Outliner. Even if I hide it, the Viewport still lags when toggling between Cameras.
Could anyone help me with this issue? I'd greatly appreciate any advice! Also, apologies in advance for my poor English; it's not my first language.
