MASH Instance to Object- Cannot see Instances
bradaschreiber
Message 1 of 9
bradaschreiber
I am instancing a Tree onto a plane and whenever I create a MASH network and select a Plane to Instance the object onto- i cannot see the Instances. I can see the Base Mesh I am instancing fine- but not the Instances on the selected object.
Any idea what the issue is?
Replies (8)
Message 2 of 9
sean.heasley
Hi @bradaschreiber
Can you post a screenshot/video of your issue and/or the scene file?
Message 3 of 9
sean.heasley
Hi @bradaschreiber
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 4 of 9
bradaschreiber
hi Sean, the problem still persists. I have attached three stills showing the Object I am instancing- the Instancing Settings- and the Mesh I use to distribute- with no Instances showing themselves.
Message 5 of 9
mspeer
Hi!
What units are you using (default set to "cm" or something different)?
Message 6 of 9
sean.heasley
Hi @bradaschreiber
Yeah like @mspeer  said please check what units you are using.
Also, a quick test you can try is unloading then reloading the MASH plugins to reset them and make sure nothing is wrong on that end.
Message 7 of 9
sean.heasley
Hi @bradaschreiber
Message 8 of 9
bradaschreiber
Hi Sean, yes I have found the issue here-thank you very much, it has been fixed.
Message 9 of 9
bradaschreiber
I discovered this was a scale issue- the object in question had not been properly adjusted to relative scene scale.
