I am working on maya 2020 version using redshift render engine. I have created redshift refrence proxy of trees animated sequence and import to my scene it was perfectly open and woking till now on ipr then I add mash node and distribute proxy in ipr it was not rendring mesh instead of mesh it render boxes are present there
Solved by sepu6. Go to Solution.
It works, but if you want to instance a rs proxy you have to use the instancer instead of the repro node.
Yeah! I figured it out while creating mash network i have to cheack instance intead of mesh. Thankyou.
