I keep having issues with the marking menu getting stuck. Everytime I left-click to perform an action such as moving an object, rotating, deselecting, or just about anything, ... the marking menu pops up instead. I have to restart or click onto my desktop to try and fix it. I have no idea whats happening or why. I do not have anything special in terms of hotkeys etc, it just does it randomly. It is incredibly frustrating when I am trying to get work done. Does anyone have and idea if this is a known bug?
I'm on OSX, Maya 2016.
Same issue here. Maya 2016 SP 3; OS X 10.10.3
Also reported, but as of yet unsolved here: http://forums.autodesk.com/t5/maya-general/intrusive-marking-menus-maya-2016-mac-os-x-10-10-3/m-p/56...
Yes, it's an ongoing problem.
Try hitting the W key. That seems to work for me. If not, try E, THEN R.. One
of them should reset the pointer tool.
Dude, I dont often reply or give Kudos, but you just SAVED MY LIFE!
Thank you
@Anonymous Not that this failure on the part of Autodesk's UI team is acceptable in any way, but thank you so much for that quick fix!
This is still happening in Maya 2022.3
How is this still a thing after this many years? Having to hit the W, E, or R keys again is NOT a solution. It's a bandaid, at best .
C'mon guys...
For the record, I am STILL dealing with this too. This issue has been going on for.. what 6 years now, at least?
LOL..
Do you have a reliable way to reproduce the issue or is it random?
Thanks.
We were able to reproduce this issue if Maya lost focus (so you went to another program) and then regained it (made Maya active).
Is this what you may have been doing?
We've logged this as MAYA-121644.
I have experienced this when doing a lot of work involving the marking menu. So, if you want to reproduce it, model something in polys for a few hours using the marking menu as your primary tool, right clicking over components, using ctrl and shift modifiers.
the year is 2024, 9 years after this was discovered. a bug that occurs every 10 seconds in some cases and slows the user down considerably. this is some serious incompetence and is really making me consider learning blender as many of my colleagues are/have.
