AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
Low GPU Usage for Arnold 6
dangoldstein
Message 1 of 9
dangoldstein
Just noticed in my Win10 Task Manager that the GPU only has about 6% utilization while CPU has about 30%. This is WHILE rendering a frame with the Arnold GPU (4.0.1 in Maya 2019). GPU render setting is turned on in the System tab. I am using a brand new RTX 2080 Ti and have the latest drivers. Is there a way make the GPU usage higher while rendering? Is this normal?
Replies (8)
Message 2 of 9
Just did a test to see my CPU to GPU usage.  The CPU usage jumps dramatically if I do not turn on GPU in the settings.  Turning on GPU drastically reduces the CPU usage.  I'm not sure there is a way to make the GPU use more than the CPU.  It may be that the GPU just crushes the render so fast that the CPU usage is normal.
Message 3 of 9
dangoldstein
Agreed, the GPU does a great job. However, using the GPU for a render shouldnt result in such a low GPU usage percentage. Especially on very large scenes where the GPU seems to be taking 30 minutes on one frame at only about 6 percent usage, I am wondering if the usage should be much higher to get the render completed faster on my 2080 Ti. I even installed the Nvidia Studio Driver and havent noticed a difference in render times.
Message 4 of 9
Hello, using Nvidia RTX 8000 graphics card if i render batch in maya 2020 with arnold 6, (GPU render type in render settings)
still maya performance is in CPU not in GPU. CPU 100% and GPU 20%, does arnold 6 with maya supports 100% rendering in Batch render?
Arnold 6 for maya (GPU Rendering) is only supports,
1. Interactive render?
or
2. Batch and Sequence Render also?
Please help me
Message 5 of 9
I'm seeing the same issue. latest nvidia drivers. Quadro P620. I'm getting better performance on my CPU than GPU
Message 6 of 9
Christoph_Schaedl
Are you using GPUz to monitore your Graphics card?
The Task manager isnt doing a great job in this case.
https://linktr.ee/cg_oglu
Message 7 of 9
I am, also, render is actually slower on GPU
Message 8 of 9
Stephen.Blair
Batch render is not the maya process. You have to look at mayabatch
// Stephen Blair
// Arnold Renderer Support
Message 9 of 9
Stephen.Blair
Please post an Info-level log for a render, so we know what's going on and have a starting point for a conversation.
// Stephen Blair
