Larning to write code in with Python
kazinsks
kazinsks
learning to write code and started with video 1 day one on you tube and can't get a simple scrip to run correct withourt "syntax error". Thoughts...?
kazinsks
update scripting works in MEL but not python. However, the video for learning is for python... confusing...
RFlannery1
You need parentheses around the string to be printed.  Like this:
print("hi")
The video may be using an older version of Python.  Maya 2020 and earlier versions used Python 2.  In Python 2, "print" was a statement instead of a function.  So you could use it without parentheses.  But in Python 3, "print" is a function.  And functions require parentheses.
kazinsks
beautiful! Thanks
