it won't let me open my files
orbitaee
orbitaee
Community Visitor
Community Visitor
I get this code every time I want to open my files, then it closes automatically.
"Cannot find procedure "openRecentFile". Start of trace: (command window: line 1). openRecentFile (command window: line 1)"
Then I get this longer code
"loadPlugin renderSetup;
// renderSetup
// Error: line 1: Cannot find procedure "MTsetToggleMenuItem".
# Error: module 'vaccine' has no attribute 'phage'
# # Traceback (most recent call last):
# #   File "<maya console>", line 1, in <module>
# # AttributeError: module 'vaccine' has no attribute 'phage'
# Error: name 'leukocyte' is not defined
# # NameError: name 'leukocyte' is not defined
// Bifrost: Pre-loaded mayaUsdPlugin to access proper Maya USD libraries.
// Loading Bifrost version 2.7.0.1-202303200742-06aa76e
// Bifrost: Loading library: Amino, from: Autodesk.
// Bifrost: Loading library: AminoMayaTranslation, from: Autodesk.
// Bifrost: Loading library: bif, from: Autodesk.
// Bifrost: Loading library: bifrostObjectMayaTranslations, from: Autodesk.
// Bifrost: Loading library: geometries, from: Autodesk.
// Bifrost: Loading library: fluids, from: Autodesk.
// Bifrost: Loading library: particles, from: Autodesk.
// Bifrost: Loading library: file, from: Autodesk.
// Bifrost: Loading library: mpm, from: Autodesk.
// Bifrost: Loading library: modeling, from: Autodesk.
// Bifrost: Loading library: nucleus, from: Autodesk.
// Bifrost: Loading library: simulation, from: Autodesk.
// Bifrost: Loading library: riv_types, from: Autodesk.
// Bifrost: Loading library: riv, from: Autodesk.
// Bifrost: Loading library: scatter_pack, from: Autodesk.
// Bifrost: Loading library: graphs, from: Autodesk.
// Bifrost: Loading library: usd_pack, from: Autodesk.
// Bifrost: Loading library: usdMayaTranslations, from: Autodesk.
// Error: file: C:/Program Files/Autodesk/Maya2024/scripts/muscle/cMuscle.mel line 505: menu: Object 'mainRigDeformationsMenu' not found.
// Error: file: C:/Program Files/Autodesk/Maya2024/scripts/startup/ModObjectsMenu.mel line 56: setParent: Object 'mainModifyMenu' not found.
// Error: Failed to register Initialize Maya Modify menu. Cannot add Convert Primitives to Polygons menu item.
// AbcExport v1.0 using Alembic 1.8.3 (built Apr 19 2023 14:41:12)
evalDeferred "shaderBallRendererMenuUpdate";
import arnold
import mtoa
import mtoa.cmds.registerArnoldRenderer;mtoa.cmds.registerArnoldRenderer.registerArnoldRenderer()
updateRenderOverride;
import mtoa.viewport;mtoa.viewport.add_controls()
// AbcImport v1.0 using Alembic 1.8.3 (built Apr 19 2023 14:41:12)
// Error: file: C:/Program Files/Autodesk/Maya2024/scripts/others/addSelectTypeItem.mel line 101: Cannot find procedure "updateSelectTypeItemState".
// Error: line 1: initializePlugin function failed (gpuCache)
// Error: line 86: Cannot find procedure "buildDefaultHotBoxMenu".
// Error: file: C:/Program Files/Autodesk/plug-ins/lookdevx/scripts/LookdevXGraphMenu.mel line 87: menu: Object 'mainWindowMenu' not found.
// Error: file: C:/Program Files/Autodesk/Maya2024/scripts/startup/ModCreateMenu.mel line 1181: menu: Object 'mainCreateMenu' not found.
# Error: Error occurred during execution of MEL script
# # file: C:/Program Files/Autodesk/Maya2024/scripts/startup/ModCreateMenu.mel line 1181: menu: Object 'mainCreateMenu' not found.
# #   File "C:\Program Files\Autodesk\Maya2024\plug-ins\sweep\scripts\sweepMenuItems.py", line 30, in add
# #     mel.eval("ModCreateMenu " + g_mayaCreateMenuID) # MAYA_LOCATION/scripts/startup
# # RuntimeError: Error occurred during execution of MEL script
// Error: file: C:/Program Files/Autodesk/MayaUSD/Maya2024/0.23.1/mayausd/MayaUSD/plugin/adsk/scripts/mayaUsdMenu.mel line 57: menu: Object 'mainCreateMenu' not found.
// Error: file: C:/Program Files/Autodesk/Bifrost/Maya2024/2.7.0.1/bifrost/scripts/bifrostGraphMenu.mel line 388: menu: Object 'mainCreateMenu' not found.
// Error: file: C:/Program Files/Autodesk/Bifrost/Maya2024/2.7.0.1/bifrost/scripts/mw_loadui.mel line 120: setParent: Object '' not found.
// Error: file: C:/Program Files/Autodesk/Maya2024/plug-ins/MASH/scripts/MASHCreateUI.mel line 79: setParent: Object '' not found.
// Error: file: C:/Program Files/Autodesk/Maya2024/plug-ins/xgen/scripts/muAddShelfButton.mel line 125: Object '' not found.
// Error: line 1: Cannot find procedure "shaderBallRendererMenuUpdate".
updateRendererUI; "
ntt16092003
Community Visitor
Community Visitor
did you fix it? i have the same issue 😭
