Is there a way to select every other face in maya
Message 1 of 14
Bonus tools doesnt work, and I dont feel like spending a whole week to figure out how to script a tool for something so stupid that EVERY other 3d program has.
Replies (13)
Message 2 of 14
mspeer
Hi!
No, in Maya (up to Maya 2017) there is no procedural selection type like select every nth component.
You may post this to the Ideas for Maya section (Help -> Speak Back)
Message 3 of 14
Hi!
What do you mean exactly by this? Are you talking about selecting the faces of an object except one? For example, a cube has 6 faces (if you don't have any subdivisions), if you wish to select all but 1 face you can position your screen so you can left click and drag over all faces except one, or use the shift key and click each face separately while holding down shift.
Sorry if this isn't what you meant. If your looking something that's a little more intuitive and easy then yeah I'd suggest Bonus Tools, but looks like you haven't had much luck.
Happy mayaing!
Message 4 of 14
If you start off the pattern of faces you'd like to select, then you can try using 'Select > Similar' to continue the selection pattern. You can also refine the similarity tolerance to refine your selection. Hope this helps.
Message 5 of 14
syracoj
Sorry for being so late to this party.
And...there may be a hidden way to do this in the modeling toolkit that I am not aware of. There is lots in Maya that is hidden...
But for faces, what could be done is you could select a loop of faces then run the following:
source getFaces;
string $selectedFaces[] = `getFaces`;
int $x;
for($x = 0; $x < size($selectedFaces); $x++){
    if( ($x % 2) == 0 ){
        select -deselect $selectedFaces[$x];
^ the above code could be added to the shelf.
to invert, just hold down shift and select the currently selected faces and it will select the unselected faces and deselect the currently selected faces.
Message 6 of 14
syracoj
hmm...
this will work on primitive objects but once the face count changes this may fail. May need to revisit with a different solution. Will also talk to the team about finally getting a pure solution for this built into Maya other than a script approach or bonus tool.
Message 7 of 14
mspeer
Hi!
@syracoj
As far as i know currently the only option for something like this is polySelect with -everyN, which is very limited and of course not procedural.
Hopefully Bifrost Graph will help with this in future.
Message 8 of 14
malcolm_341
Wow, thanks a lot I've been trying to figure out how to do this in Mel for a while now, going to see if I can use this technique to get my script working for verts and faces. I see everyone's figured out how to do it in Python, but this is the first time I've seen it done in Mel.
Message 9 of 14
syracoj
be advised malcom_341 that that mel approach will not work once the topology changes. So it's not a very good workaround.
Message 10 of 14
malcolm_341
Well that's a major problem, any suggestion for making this work on something other than a primitive?
Message 11 of 14
ewu77A7V
Observer
Observer
THANK YOU!!!!!
Message 12 of 14
malcolm_341
Doesn't work on anything other than a primitive.
Message 13 of 14
syracoj
Yes, the script was only written to target poly faces.
It really isn't a great solution either because once you make modifications to the geometry the face reordering prevents it from working properly. We should really look at putting in a properly implemented selection tool that does this.
Message 14 of 14
malcolm_341
Agree.
