Hello, I was making a custom rig for a character and working with custom attributes. I seem to have accidentally created some of these attributes as ints, but they should really be floats. Unfortunately they have already gone through connection editor to affect the skeleton, so I was wondering if there was an easy way to change an attribute type from int to float. Thank you for reading and your time.
Hi!
I don't know an easy way. The best would be to create the attribute again.
You could also try an utility node to change the values of your integer output.
for Set Driven Key issue.
select driver
Modify>edit attrib
adjust the min/max value (in my case, -2 to 10, I changed to -20 to 100)
select driven
open graph editor
adjust keyframes
I had this question too and saw no answers but luckily found one on youtube:
https://www.youtube.com/watch?v=OgXr-ZYjRgg
Basically, you save your file as an Ascii file (so .ma). Then open it using a text editor like TextEdit on Mac or whichever one you have on your computer. Ctrl+F (or Cmd+F on Mac) to open up the search box. Then type in the attribute name you are looking to change, and search for it. In my case it was the blink attributes I was looking to convert to a float, so I just typed blink. You'll see something like this:
The string "long" means it's an integer. If it were a float, it would say "double". So simply change the word "long" to "double" as I did in the highlighted text and save it. When you open up your scene in Maya again, the attribute will be a float!
