Like I said into the title I would like to import some pmx or at least pmd models into maya but it writes "unrecognized file type" so I wanted to know if it was possible (and texturized would be better) by any way.
Thanks a lot if you can help me.
Well if you know a way to use the .ecl type I'm open to any sollutions as well ^^
the only way I've been able to get it to work is by getting Blender and using this https://translate.googleusercontent.com/translate_c?depth=1&hl=en&prev=search&rurl=translate.google....
its pretty easy to use
but can be a pain when making models from scratch
install the plugin in Blender (tutorials all over the internet dont worry)
them Import your PMD/PMX file into Blender!
then you gotta...export the model that shows up...as a .FBX
MAKE SURE YOU REPOPEN THE FBX IN BLENDER FIRST and clean the rig a smidge as it creates alot of unnessasary bones
then go into maya's setting and allow it to import a FBX
import the FBX through the importer...drag drop will not work...
WAIT! FBX files are HUGE depending on the model..it will take a long time to load
once it loads you can resave it as a MB or MA so it can be opened in Maya super easy!
be warned that and .SPA texture files will not work...and all IK's will be broken...Physics will not transfer over so you have to manually move each part of a dress
and there are no default positions in the rig
its like animating fingers....for everything...have fun
You can use mmd4maya which is maya plugin. it sometimes messes the texture but you can re-texture by simply assigning materials again
or if you want to import model with animation, use mmdbridge. i don't know much about it, but guess it converts model with animation to alembic file
Hello, I was curious if it also keeps the physics properties? I'm newer to animation so I don't know much about Maya's capabilities when it comes to physics.
