I've been running into this problem in Maya where I would click render and this would get this error. Does anyone have a possible solution?
Solved by Stephen.Blair. Go to Solution.
Can you open the script editor and see if there's more information in the script history?
Is there anything wrong in here. I don't really know what I'm looking at.
I don't think those"syntax errors" matter, and they don't happen with newer versions of MtoA.
Unless you've both render callbacks defined in the Render Settings (for example, a Pre IPR callback). That's where those syntax errors come from, I think.
