Invalid path was specified. :(the path containing my project)
Hi. For some reasons, I decided to change the name of the directory my maya file is in. Now when I try to save the file, it shows the error as shown in the title. The error makes sense since the previous directory with the original name no longer exists......but how do I fix it now?
n8skow
You should be able to resolve your issue by going to 'File->Set Project' and establishing the correct location for your files.
It is not working...I successfully reset the path inside "set project". But when I try to save it, the same error occurred with my old path showing up....
n8skow
Can you give a bit more info on what the error is that you are seeing?
No problem. Here are the screen shots.
Here is the error message showing my old path of the file.Screen Shot 2018-11-03 at 9.32.22 PM.pngHere is my revised "set project" window showing the path I want to file to be saved into.
Has OP solved this issue? I'm having the same issue as well 😞
adrien.segura
Observer
Observer
The problem is the spaces in the path i think ("asset 1" and "game building" should be renamed "asset_1" and "game_building"
