Import options description
PuChiNgBaLLz
PuChiNgBaLLz
Hi there, I'm trying to figure out what's the difference between these sample types import options in Aruba tessellation
Entire Domain
G1 Segments
Per Span (Default value)
Knot Values
Adaptively
Documentation says nothing about it, Autodesk should describe what a blackbox does
https://help.autodesk.com/view/MAYAUL/2026/ENU/?guid=GUID-37B31221-7BBC-40DA-AB33-47C333EF4E14
bhavani_sankuratri
Hi @PuChiNgBaLLz
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
Bhavani Sankuratri | Community Manager
PuChiNgBaLLz
No, how can I find a solution if the documentation is incomplete?
Stephen.Blair
Maybe this AI-generated description can help? I'm not working on the Maya code so I haven't checked what that code actually is doing.
Based on standard NURBS tessellation terminology, these options can be understood as follows:
Sample Type What it does Typical Result
Entire Domain Treats the entire U/V parameter domain as a single region and distributes samples across it. Most uniform sampling, but may miss local detail in areas with uneven parameterization.
G1 Segments Splits the surface at G1 (tangent continuity) boundaries and samples each smooth patch independently. Better preservation of creases, fillets, and tangent breaks.
Per Span (default) Samples each NURBS span separately (a span is the region between knots). Good balance of accuracy and performance; generally the safest choice.
Knot Values Places samples directly at knot locations in the NURBS definition. More faithfully follows the original NURBS structure, especially where knot density varies.
Adaptively Adds or removes samples based on curvature/error metrics rather than a fixed distribution. More polygons in curved areas, fewer in flat areas; often the most efficient for complex shapes.
When to try a different Sample Type
If you're seeing:
  • Faceting on curved surfaces → try Adaptively or Knot Values
  • Problems near trims, fillets, or continuity breaks → try G1 Segments
  • Uneven tessellation density → try Per Span or Adaptively
  • Unexpected artifacts from CAD imports → try Knot Values, since it follows the NURBS knot structure more closely
// Stephen Blair
// Arnold Renderer Support
lauri_barnhart
Hello @PuChiNgBaLLz, we appreciate you posting your question.
Did the post by Stephen.Blair help you and answer your question?
If this fixes the issue, please go ahead and accept it as the solution.
This ensures others can benefit from the resolution shared here.
If you still require support, please post an update so we can assist you further.
Lauri | Community Manager
