Import External File - MEL?
jayantbhatt07
jayantbhatt07
Hi guys I'm working on a script where I wanna import external file into my existing scene but as you can see in the screenshot my path is fine for me but if I upload this script on highend, user has to change the location which I don't want. I have seen script where people are using some other commands to import the file But I couldn't figured it out. LIKE THIS (
global proc string[] Character_scale () {
string $X = (`internalVar -userScriptDir`) + "scripts/3D_Ghost_Script/Files/UE4_Man_Scale.ma";
}    DON'T KNOW WHAT HE DID?
Any Help???
rajasekaransurjen
The following is the Default script folder path for Windows
<user’s directory>/My Documents/Maya/<version>/scripts
We can query it with `internalVar -userScriptDir` command.
in my system the above code returns
internalVar -userScriptDir;
// Result: C:/Users/USER/Documents/maya/2019/scripts/ //
in your system it will be
// Result: C:/Users/Jatant Bhatt/Documents/maya/2019/scripts/ //
As per your screen shot.
So you can paste the "3D_Ghost_Script" in the above path.
string $X = (`internalVar -userScriptDir`) + "3D_Ghost_Script/Files/UE4_Man_Scale.ma";
// In this above code the `internalVar -userScriptDir` will return C:/Users/Jatant Bhatt/Documents/maya/2019/scripts/
// You string concatenate the result with ""3D_Ghost_Script/Files/UE4_Man_Scale.ma"
// Now the string $X will have the complete file path.
// That is "C:/Users/Jatant Bhatt/Documents/maya/2019/scripts/3D_Ghost_Script/Files/UE4_Man_Scale.ma"
// So now you can use the $X to import the file UE4_Man_Scale.ma.
Please refer
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Maya-Env...
https://download.autodesk.com/us/maya/2009help/Commands/internalVar.html
jayantbhatt07
Procedure is missing a return statement. I'm getting this error.
jayantbhatt07
global proc string[] UE4_Man_Scale()
string $file_Path = (`internalVar -userScriptDir`) + "3D_Ghost_Script/UE4_Man_Scale.ma";
file -import $file_Path;
jayantbhatt07
global proc UE4_Man_Scale()
string $file_Path = (`internalVar -userScriptDir`) + "3D_Ghost_Script/k.png";
