hello friends. i imported image with image plane. But i cannot see it. here is video. can you help me please?
https://www.youtube.com/watch?v=_sIuWzGYGhY
Solved by john.paul.giancarlo. Go to Solution.
hello see the image bellow , can you make sure the display is not set to outline?
I cannot see the settings well in the youtube video, also try to save your image again as jpg just to be sure is not an image index setting issue.
1- can you share your files with me so I can have a look?
2- Did you try updating your graphics card drivers?
3- what are your systems specs ?
please share this information with me, I will help you figure out your problem
JP
i hope these are what tou want from me.
all problems are solved when i update my graphic card. thank you friend. 🙂
