Image plane disappeared 2018.2
I've done a lot of searching and found similar issues but nothing quite the same. I have multiple image planes in the scene which I added through view > image plane > import image. I do this for each view, and in image plane attributes, i set display to looking through camera front for instance. If I set up two image planes for front and side views, and set display to looking through camera, when I load the scene after closing it the image planes are no longer visible in the appropriate views.
To get the planes to work again, I have to click in all views, and switch it back to looking through camera. I have to do this every time I reload a scene with image planes.
mspeer
Hi!
I can confirm this.
This is clearly a problem with Viewport 2.0,
the file is saved correct, the connections are there  and it works if you select a Legacy Viewport for your Panels.
With Viewport 2.0 only one imagePlane will be displayed.
Please report this problem (bug?) to Autodesk.
Help -> Speak Back -> Report a Problem
Good idea. Hopefully they're able to reproduce it.
s3789857
Observer
Observer
Just for anyone else like me desperately looking for a fix,
For some reason if you create a blank plane in the environment tab of camera (in attribute editor) and load the image, it works fine. Not sure how or why.
