Announcements
I saved my project but when I open it, the nCloth simulation doesnt work.
Yesterday i was working on a project with a rigged model from the content browser and then i applied an nCloth simulation. Everything was fine until today when i opened my scene, the nCloth simulation doesnt work and if i tried to do it again, the model dont react no anything.
Also i saved the Cache yesterday but its useless.
I so confused because before to save it everything was fine. 😞
sean.heasley
Hi @Anonymous and welcome to the community!
A quick test you can try is to select everything in the scene file and export it as an FBX then import it into a fresh empty scene.
If that doesn't work, when you get a chance can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it?
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
