Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
I have problem with Append to polygone tool. Could you give me your opinion?
5 REPLIES 5
coo533
337 Views, 5 Replies
Append to polygone tool doesn't work well.
could you watch this short video?
5 REPLIES 5
damaggio
in reply to: coo533
you have reversed normals visible in your mesh, the black faces, invert those, that’s not good, ( Read about what normals are)…also you are piling up on history on an . Mb file that could get corrupted if crashed, use .ma files, make sure you enabled incremental save.Also it’s easier to select a bunch of edges at once and use the bridge tool.
brentmc
in reply to: coo533
Yes the problem is related to the face normals. Because the normals are facing opposite directions the new polygon is twisted 180 degrees.
1) Mesh Display > Reverse can be used to flip normals on black polys.
2) Mesh Display > Conform  can be used to ensure the normals on your mesh are consistent from poly-to-poly across an entire mesh
Also, QuadDraw can be used without a live surface to quickly add bridging quads to your mesh. However, it would also require the normals to be consistently oriented. The other caveat with QuadDraw is the new polys will be flat shaded so you will have to use something like Mesh Display > Soften / Harden Edges to smooth out the shading later.
Brent McPherson
Principle Engineer
coo533
in reply to: coo533
 I appreciate your help on this matter.
coo533
in reply to: damaggio
coo533
in reply to: brentmc
