Hypershade tabs gone
Message 1 of 11
Hi, I accidentally removed all my tabs in Hypershade, how do i get them back ?
Replies (10)
Message 2 of 11
sean.heasley
Hi @Anonymous and welcome!
You can try deleting your settings/preferences
Let me know if this solves your issue!
Message 3 of 11
Hi,thanks but this folder can’t be found ...
Message 4 of 11
sean.heasley
You cant find your folder with your settings/preferences?
It should be in Documents>Maya>2017 and it will be labeled 'prefs'
Message 5 of 11
Hmm, no its not there… is there a way to manually add all the tabs back ?
Message 6 of 11
Hi, Im not sure why it doesn't work ... I can't find my preferences folder.. hmmmm.
Message 7 of 11
Hi,sorry  is this the one ?
Message 8 of 11
if you want, you can go to "Window" at the top of the hypershade window and select the first five items one at a time. then, you can arrange the windows that pop up.
Message 9 of 11
sean.heasley
Hi @Anonymous
Try what @Anonymous suggested but if that doesn't work you may want to do a full uninstall and reinstall of Maya.
Message 10 of 11
mspeer
Hi!
Just to make sure, you replaced "USERNAME" with your "username" like "deblsc" or whatever your user account on your computer is named?
(You may try a reset inside the Preferences window inside Maya but this might not be enough)
Message 11 of 11
oh yes i finally found the folder, after renaming the preferences folder my hyper shade tabs go back to the default ! thank you so much !
