Hypershade - Can I make the window in Property Editor be automatically resized whenever Hypershade is turned on?
tjdrbrla
Message 1 of 1
tjdrbrla
Can I open a panel in a hypershade to reduce the window size of the panel properties to the desired window size? I'd like to resize the window in the Properties Editor as shown below..
Also, if you reopen Hypershade, the Create window will return to its default value instead of the desired window size.. This is why we can increase the window enough, and I hope there is a way to fix this problem by opening HyperShade's Panel.
Replies (0)
