The default is HD_540 but I set this to HD_1080 every time.
Is there any way to set this to HD_1080 at startup?
Solved by Abdulla-Qaladzay. Go to Solution.
Hi Amaterasu.qbb
this information get saves in the scene file we can reuse the code at Maya start-up script file:
-set you favorite "common render settings" in a empty scene
-save it as maya ASCII (.ma)
-find the responsible script in a text editor
defaultRenderGlobals
defaultResolution
-make a Maya stat-up script in this path (Documents\maya\2018\prefs\scripts\)
-past the script in a global proc then save it
* pleas watch the video attachment "defaultRenderSetting.mp4"
