How to make texel density have high resolution ?
Hello. i have uv then go to substaint painter for texture, but the texel density is too low so i get pixel when painting ( i try on 4K res ) . I try to scale bigger than uvmap but it seem broken my uv. ( texture not working ). How to improve that ?
I try to search on this forum, on internet, youtube but didn't work.
I try to uv one by one part of my model but didnt work well...
I dont know how, someone make them model so deltai when zoom in becauz their textel density is high resolution ?
Sorry for my bad english. Thank for read my topic.
sean.heasley
Hi @Anonymous
It looks like you only did an Automatic Mapping and didn't properly UV map the model.
You'll want to break up the model into a handful of shells so you can save on space and make those shells larger so you'll have more room to texture. One trick for example would be to UV map the wheels and then stack their shells on top of each other. That way they'll all share the same tire texture but take up 1/4 the amount of space.
You could also use UDIM texturing. You can find a tutorial on that here:
If you need more assistance or still aren't understanding this, I'd be happy to take a look at your file and make a quick tutorial for you! All you need to do is zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it!
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
