How to do move rotate scale a bit(1/100-1/1000)step snap?
amaterasu-qbb
amaterasu-qbb
The step snap is in Tool Setting and can be input up to 0.01, but if you try to operate it with the Manipulator, you will see the following error message.
It's not a Step snap at all. (Even if it is, it's so small that it's hard to tell.)
Also, dragging with the middle button moves too much, even if I increase the size of the Manipulator.
Can you tell me another way to switch between slowest in Channel Box?
How do I do it with the Manipulator?
brentmc
See this post for how to precisely transform objects using the channel box:
https://forums.autodesk.com/t5/maya-forum/how-to-make-the-rotate-move-and-scale-tools-more-smooth/m-...
Brent
Brent McPherson
Principle Engineer
amaterasu-qbb
Is there any other way?
Especially with the Manipulator visible?
brentmc
The manipulators are using direct interaction so for rotate/scale you could try increasing the size of the manipulator (using NumPad +/- hotkeys) which should give you finer control. Similarly, you could try zooming into the object when using the move tool.
I'll log an improvement to allow finer control when using the transform manipulators.
Thanks.
Brent
Brent McPherson
Principle Engineer
amaterasu-qbb
Hi! @brentmc
I could not prove that making the manipulator bigger moves the rotation slightly.
So I look forward to future updates.
Best,
